Electrification & Control => Radio Control => Topic started by: Traininvain on Dec 01 2014 09:48
Title: Radio control for review
Post by: Traininvain on Dec 01 2014 09:48
Does anyone have any experience of the following R/C systems which they could do a write up on for the G3 Newsletter:
1. Systems made by RCS: http://www.rcs-rc.com/ and the similar Tx-20 and Tx-21 which are marketed by Peter Spoerer: http://www.peterspoerermodelengineers.com/90275/info.php?p=2
2. The Revolution 57000 system
Also does anyone have any experience of using their smart phone to control their trains?
tx
Title: Re: Radio control for review
Post by: Moonraker on Dec 02 2014 22:57
I have experience of all of these and use most of them on my railway layouts. I use the RCS system on my Gauge 3 railway, the Revolution on my G Scale railway and a Hornby smart phone system (plus others) on my indoor OO layout. I am familiar with the Peter Spoerer system and have one on order at the moment.
I would be happy to do an article. How long should it be and by when is it needed?
Peter Lucas
Post by: Moonraker on Jan 16 2015 06:50
I emailed the article to you a week ago but have not heard anything from you. Did you get it?
Peter Lucas
Post by: Peaky 556 on Jan 16 2017 08:54
Did the article appear; I don't recall it?
I'm in the market for a reasonably competent system that is switchable between different models but without breaking the bank. Any suggestions?
Thanks Tim
Post by: cabbage on Jan 16 2017 09:23
The article appears in issue 100 of the Newsletter (spring 2014). I am looking at the Deltang kits.
www.deltang.co.uk  (http://www.deltang.co.uk)
Post by: Andy B on Jan 16 2017 19:30
I thoroughly recommend Deltang kits if you enjoy wielding a soldering iron.
Post by: Richard T on Jan 16 2017 20:23
I'll go with Andy on that, I've built quite a few of their systems - very good.
Post by: Doddy on Jan 16 2017 20:42
Quote from: Peaky 556 on Jan 16 2017 08:54
I am using the Revolution controller and receivers but gets ruled out due to your rules on costs.
Post by: Peaky 556 on Jan 17 2017 07:40
Thanks guys; there looks at first sight to be a bewildering array of products at Deltang, but I'll look in more detail.
One day I might have some tunnels to contend with, so a powerful system ought to be on the cards.  Any experience of range from you guys?
Post by: Doddy on Jan 17 2017 07:44
It's not just a matter of range, the Revolution allows the locomotive to continue at it's set speed when the radio link gets dropped, thus allowing the loco to come back into range and under the users control. It may well pay you to see what the Deltang Solution does in this respect.
The Revolution uses 2.4Gig radio and is good for over 400' outdoors.
Post by: Andy B on Jan 17 2017 08:11
Quote from: Peaky 556 on Jan 17 2017 07:40
If you are looking for an RX /controller for brushed motors with a current capability of 3A +, then basically there are 2 Deltang products of interest - The Rx65 & the Rx102.
However there are several variants of both.
The user can set the 'no-signal' parameter on both of the Deltang Rx's mentioned above to either stop on loss of signal, or to continue at the last set speed.
The longest range I've tried mine on is on Ralph's line - but you're welcome to borrow Thomas with the 'low power' Tx 20 transmitter and do some tests around your house or in a simulated tunnel.
My other Tx is based on the Tx22, but uses a higher powered 'Orange' Tx module controlled through the Deltang CB2 - also welcome to borrow and test.
Post by: AllWight on Jan 18 2017 14:48
I ham sticking with my spektrums and futabas. I have a mix of 27Mhz, 40 Mhz and 2.4Ghz all locos work really well so no need to change them and i am not into the sound effects as its not right for me and does not sound right on the model. I drive bigger engines in my spare time whatever spare time is!.
I am still not convinced the sound effects are up to scratch to replicate the behaviors of an engine at idle rolling, under labour on uphill, level or downhill grades.
There are some good sound modules out there such as the Massoth systems that my dad has on his LGB and american 0n30 models. One of his steam locos for me is spot on and it is 2-4-4T of a Forney that is spot on in every sense. I have yet to see another that good in any scale.
Post by: Traininvain on Jan 18 2017 18:50
If I were you I'd forget the Deltang and related systems and the Revolution too and check out the GigaRad stuff from Timpdon Electronics
http://www.timpdon.co.uk/timpdon/telec/products/products_grc.php
From what I understand, the guy who runs it, Geoff Garside, used to work for GEC traction and really knows his electronics.
I've tested this system with Brian Jones' old and new speed controllers and the new one from Timpdon using cored and coreless motors and the results are excellent.
Post by: Andy B on Jan 18 2017 19:21
Quote from: Traininvain on Jan 18 2017 18:50
I hope that in general we can be more open minded!
Have you ever spoken to David at Deltang? Do you know anything of his background? Have you done a quantitative comparison of these products? Similar the proprietor / designer at Revolution.
I think you will find that several of us have had excellent results using Deltang products, and also Revolution.
I had never heard of Timpdon before today, and it looks as though they do have a good range of products.
Having not tried them, I cannot comment on their performance! However I will make the observation that in terms of features, Deltang offer a very compact combined Rx and ESC, but I don't see a similar item in the Timpdon line-up. To reiterate, that is no reason why I would not encourage potential buyers to consider / compare the Timpdon products to see what might best suit their needs.
Post by: cabbage on Jan 18 2017 20:29
Well..
Having looked at the Timpdon site I don't think they have what I need. I have the choice of the Deltang 12 loco controller and the 3 loco controller. Although I really like the "Bangs per Buck" of the 12 loco controller I think it is the 3 loco controller that I will buy...
The reason is that I cannot see me using more than 3 locos at once on my layout. The Timpdon system only seems to offer a single loco controller(?)
Maybe Tim and I could coax Andy B for some module lessons???
Please(!)
Post by: Andy B on Jan 18 2017 21:01
Quote from: cabbage on Jan 18 2017 20:29
Sure - let me know when you've got your bits and we can have an 'RC' afternoon!
Remind me to bring my file with me containing the instruction sheets and my scribbled notes / reminders - then i might have some chance of remembering exactly how I did things!
Post by: Doddy on Jan 19 2017 04:47
Wow! Don't promote products used by members of this society? - OK!
Post by: Traininvain on Jan 19 2017 10:21
Andy is right, I stand corrected on all counts. My apols to all Forum members
Post by: Peaky 556 on Jan 19 2017 13:30
Quote from: cabbage on Jan 16 2017 09:23
Hmmm, that is one of the mags I am missing, so I'm hoping there will be back-copies available at the AGM.
As for Deltang, not an altogether helpful experience.  All I can establish is that they cannot cope with any higher voltage than 18v. I am tending to use SLA batteries, including a stack up to a nominal 18v, but of course that can exceed 18v when fully charged and rise to 21v during charging.  I have been in touch with David and he can offer no other guidance on selection.
I have emailed Timpdon Electronics with a bit of a spec and asked for advice.  The website range looks interesting, and they claim the Tx can bind to any model with a Timpdon Rx, without approaching the model...  that sounds to be a recipe for piracy!
Post by: Andy B on Jan 19 2017 13:57
I assume your >18V requirement is for the motor speed controller, not the Rx (the latter potentially being supplied by a regulated tap).
If so, would not one of the higher capacity the MTroniks ESCs (http://www.mtroniks.net/prod/Boat-Speed-Controls/Viper_Marine_15_HV.htm) meet your needs?
This could be controlled using a Deltang Rx102 or a Timpdon GRX1
Post by: Andy B on Jan 19 2017 14:09
P.S.
Just found there is a high voltage loco-specific version too - Viper Loco 10 HV (http://www.mtroniks.net/prod/Locomotive-Speed-Controls/Viper_Loco_10_HV.htm)
Post by: Peaky 556 on Jan 19 2017 19:33
Quote from: Andy B on Jan 19 2017 13:57
Andy you're right about the 18v being for motor power.  So when an ESC is connected to both the battery and the receiver, only a reduced voltage is fed to the Rx then?  It's beginning to dawn on me than the BEC fitted to all ESCs, or UBEC as some call it, is this very convenient "regulated tap".  So I'm not clear why David of Deltang ruled out his receivers as unsuitable for my 18v system!  It may be that the two Rx that he recommends for trains, Rx41 and Rx60, both have an in-built ESC.  I don't want that, preferring flexibility.  There appear to be over twenty other types of Rx on his website, but he doesn't help himself by declining to discuss applicability.
I'll sit back and await a reply from Timpdon.
Mark, many thanks for your input, but I'm guessing all your systems are aircraft based, with fiddle-sticks? I know they work well and have a massive development programme behind them, but I'm going down the road of the more unobtrusive boxes with twiddle-knobs!
Post by: Andy B on Jan 21 2017 19:02
Thanks to David White for suggesting another supplier that I had not previously come across, and whose speed controllers have some serious power capability!:
Electronize.net (http://electronize.net/model_electronics_frames.htm) of Sutton Coldfield.
The units are quite bulky - but any model that needs the power that they can handle probably has plenty of space to accommodate them.
Post by: keith Bristol on Jan 21 2017 22:12
You can now add Piko and wireless DCC control to the list using Wifi.
Post by: Doddy on Jan 22 2017 08:02
Quote from: keith Bristol on Jan 21 2017 22:12
It might be worth elaborating here, as the PIKO system is a cut-down version of the Massoth DCC system which has wireless between the handset and the receiver which then plugs into a track fed master controller to provide DCC signals over the track.
Unless of course you have added Blue-Rail technology to have a wireless transmitter between the master controller and a DCC wireless receiver mounted in the locomotive, and also use an iPhone or similar to control trains rather than the PIKO (Massoth) hand-held controller.
Post by: Peaky 556 on Jan 22 2017 10:03
Doddy, I've checked in my Xmas stocking again but there wasn't one of those in there. :-\
Post by: keith Bristol on Jan 22 2017 21:09
Piko handset to the base station, boosted by a wifi extender, then a wire replacement Tx RX Tam Valley to the loco
Post by: Peaky 556 on Jan 22 2017 23:14
Looking again at the Timpdon systems, they don't "seem" to offer more than one proportional channel, just one for speed control and the other four or five seem to be toggle switches.  I am awaiting more info from them to confirm this, but if so, the system would not be flexible enough for me.
Looking again at Deltang, they offer a Tx with three twiddly knobs for propo outputs, plus various switched outputs, but I'm blowed if I can tell if the Rx all have built-in ESCs or not.  I am frustrated by the complete lack of advice/explanation forthcoming.  Their website is aimed at nerds in my view.  Has anyone else had luck in this respect? :( Tim
Post by: Andy B on Jan 23 2017 08:15
As I said in a post above, the Deltang Rx102 is the one you need for locos with a separate ESC.
In the 'Receivers' tables, there is a column labelled 'H outputs (motor)' which shows how many motors the unit will control.
Here, the Rx 102 has a blank- i.e. no motors.
Post by: cabbage on Jan 23 2017 20:28
Well speaking as a super knerd... The Deltang web site IS confusing... But I have persivered and I think I have a shopping list. Most of the locos will have to use external ESCs. But maybe two can use 6A rated rx units(?)
I like the idea of the three way controller - but is the 12 way more practical(?) I did send DT an email but got the reply that he was too busy to help...
Post by: cabbage on Jan 24 2017 16:16
The sound of screaming you can feel in the background is my wallet.... Having done a "truth table" on the two types I find that I require BOTH to the TX23 and the TX72!!! So, after the feeding frenzy of the AGM, (and the implicit hernia). It looks like I am going to book AndyB for a Saturday afternoons sometime in March to play soldering on the kitchen table...
Post by: Peaky 556 on Jan 24 2017 22:44
Quote from: Andy B on Jan 23 2017 08:15
I might be picky here Andy but no-one had clearly stated this.
If this guy gets my business it will be DESPITE the lack of application guidance, certainly not because of it...
:-\ Tim
Post by: cabbage on Jan 25 2017 12:17
I opted to "chat" with one of his suppliers and got a lot further! I have ordered the TX23 kit and three RX102UH receivers. So, it is off to RF POTTS ltd to get a 250 gramme reel of some more suitable solder (the stuff I use for my guitars most definitely ISN'T!).
I will also replace the supplied BLACK knobs with something more visually "user friendly". I probably will buy brightly coloured Chicken Heads or Stove Pans -something that has an obvious position indicator to it.
Tim, this the company that I talked to:
http://www.micronradiocontrol.co.uk (http://www.micronradiocontrol.co.uk)
Within 3 hours by e-mail they had made a sale!!!!
Post by: Peaky 556 on Jan 27 2017 06:46
Timpdon have given me a long and helpful reply regarding the query "Can you offer Tx and Rx combinations that will allow multiple servos to be controlled in a proportional manner?"
The GRX2 receiver controller has the fgollowing outputs, designed primarily for the control of live steam locos.
1 x fully analogue uni-directional regulator channel - Servo PWM, controlled by speed knob - servo max/min positions user calibrated.
1 x reverser channel - Servo PWM, controlled by reverser switch. This is a 3 position servo, forward - stop - reverse, with servo positions user calibrated and controlled rotation rate.
1 x auxiliary channel - Servo PWM, controlled by Aux 1 switch [ nominally for steam whistle or drain cocks]. This is a two position servo, on - off, with servo positions user calibrated and controlled rotation rate.
1 x serial data channel containing information on all switch settings. This can be used with a GAC1 controller to provide 5 switched outputs - 2 x auto forward/reverse lights, and 3 x uncommitted outputs controlled by Aux 2 to Aux 4 switches.
If you need multiple fully analogue controlled servos, then I can not offer you any suitable equipment.
For flexibility of modelling live diesel in the future this is not quite what I want, but I've repeated it here as it might help some people.
Post by: Doddy on Jan 27 2017 10:10
Quote from: Peaky 556 on Jan 27 2017 06:46For flexibility of modelling live diesel in the future this is not quite what I want
What exactly do you need the radio controller to do Tim?
Post by: Andy B on Jan 27 2017 10:11
To echo Doddy's question...
I'm really not clear now what it is you are after.
Can you define what you are looking for in terms of number of channels, the capability of each channel (on/off, forward / off / reverse, variable in one or two directions, etc and whether operating a servo, motor, etc) - repeated (if necessary) for potential different applications (all electric, live diesel-electric, etc).
Post by: Peaky 556 on Jan 27 2017 21:37
The way I see it is that Tx and Rx designed for multiple proportional servo operation will also work ESC and electronic switches.  Then I have the most flexibility for what I may want to do in the future.  I can fit any of these controls and play trains with lots of features.
Outfits with just one proportional output and various digital 'switching' functions, representing the bulk of model train stuff on the market, will confine me to one servo or ESC max.  Not quite true, other servos can be fitted but they can only work to dialled-in end points, no control in between.
Basic ones with a built-in ESC constrain my ambitions!
I have decided to go for a Tx/Rx with three proportional knob controls and several other switching functions.
I know it will take all my remaining years to explore that lot!
;) Tim
Post by: cabbage on Jan 30 2017 16:11
I have a partially coupled Deltang kit on the kitchen table. The hardest part about assembly has been the mods that I have had to do to it -to do with my failing eyesight!!! The knobs are now white and the bind button is white.
Finding black on black is beginning to be difficult....
Having done most of the fabrication with a wheel brace and a a soldering iron the next part of it requires connecting the transmitter module to the assembly. The instructions quite rightly say it is safe to simply solder direct to the 21 pins but I am going to use plugs as I believe this will make it easier for testing.
Post by: Richard T on Jan 30 2017 23:57
Deltang TX22 transmitter & RX65 receiver.
Post by: cabbage on Jan 31 2017 00:06
You have a steady hand! My box shows iron scars from a sneezing fit...
Post by: cabbage on Feb 01 2017 15:01
I am roughly three solder joints away from completion. The ESCs are on order and we wait for the union of loco to controller. The controller handset is heavily bespoke for my use. Would I recommend a Deltang kit? The answer has to be a definite Yes!
Post by: Traininvain on Feb 08 2017 14:42
Timpdon has now launched a transmitter which can control 3 battery powered locos independently, the GTX2:
Post by: cabbage on Feb 26 2017 15:08
Yesterday afternoon was spent in the company of Tim Gleed Owen and Andy Boothman at his kitchen and workshop. The TX unit was fired up for the first time and the only problems related to the "0" position on the controller. This was traced to the auto setup button on the ESC...
I have ordered a custom 12-way controller from the same people. This will have the higher power 100mW transmitter and an emergency stop button.
