This is freelance, but I do admire the engineering in it. Some of it is beautiful.
https://www.leespring.co.uk/about-us
(https://i.ibb.co/ZWNmsFM/SRS-2-6-2-a.jpg) (https://ibb.co/ZWNmsFM)
Looks interesting Mike - but the link may not be quite right! :-)
Quotebut the link may not be quite right!
At first I assumed it was a comment on the expansion link in the valve gear and tried to look closely at the photo ...... then I clicked on the URL link!
I was being a bit idle really John - it was easy enough to find. :-)
https://www.stationroadsteam.com/2-12-inch-gauge-2-6-2-with-tender-stock-code-9850/
These two "Projects" might interest some here too:
https://www.stationroadsteam.com/2-12-inch-gauge-2-2-2-locomotive-chassis-stock-code-9437/
https://www.stationroadsteam.com/2-12-inch-gauge-lms-2p-4-4-0-stock-code-9435/
One has a 'shell' tested boiler (2 x WP) ...
Sincere apologies - I was doing two things at once - ended up not doing either properly! Thanks Ian.
Must have a 'spring' in your step today Mike! ;)
