Rolling Stock => Carriages & NPCS => Topic started by: MikeWilliams on Aug 04 2010 09:17
Title: Bogies for carriages
Post by: MikeWilliams on Aug 04 2010 09:17
There have been calls for coach bogies to be made available, on the basis that not many are offered by the trade.  These are the ones I know of, but can anyone add to the list or comment on their experiences of using them?
GRS LSWR.
Etched brass with cast brass fittings.  £194.25 per pair
GRS GWR 9ft pressed steel.
Chinese-made RTR brass £79.19 per pair
GRS GWR fishbelly.
Brass and whitemetal  £165 per pair
Brandbright GWR.
No longer available, cast whitemetal.  Were they any good?  Complete or just sideframes?
Model Engineers Laser Gresley.
Under development from mainly laser cut parts with brass castings.  No further details yet.
Walsall Model Industries LNWR 8ft heavy type.
Cast whitemetal sideframes only.  £5.70, but waiting to hear whether that is each, or per pair, and whether they have any plans for a (maybe etched?) structure to go with them.
Gauge 3 Society structural steel sideframes only.  Temporarily withdrawn from sale.
Is that all, or can anyone add to the list?
Title: Re: Bogies for carriages
Post by: cabbage on Aug 04 2010 17:12
quote:
"Gauge 3 Society structural steel sideframes only.  Temporarily withdrawn from sale."
unquote:
Just when you thought it was safe to work on an R-7 transporter design that used 3 sets of them.... Any idea when they will return to sale?
Post by: IanT on Aug 04 2010 21:48
If it helps Ralph, I've got a pair of bogies (e.g. 4 sides) you can have for your project. They are in drawer marked "Future Projects".
It's a large drawer!   :D
Post by: MikeWilliams on Oct 05 2010 10:38
The Walsall Model Industries' bogie sideframes are £5.70 each.  Very nice patterns, cast in whitemetal.  Heavy (just where you want weight) and reasonably robust.  Quite similar to LBSC designs, or so I have been told.
Title: LMS bogies for carriages
Post by: Traininvain on Oct 06 2010 19:42
Would anyone be interested in accurate LMS 9ft carriage bogies. They would feature 1.4mm laser cut steel frames and bolster but would require castings for the axleboxes, hornguides and possibly the leaf springs and dampers. The axleboxes would be sprung via single coil springs, with the leaf springs cosmetic. I have a rake of carriages which could do with a bogie upgrade and will probably proceed with this anyway, but I'd like to see if there may be others interested in using any castings suitable for use with the laser cut bogie frames.
Post by: hornbeam on Jan 16 2011 12:46
Will the Society ones be available again? As I also need some at some point in the future...
Thanks.
Post by: IanT on Jan 16 2011 14:28
Yes, they already are Hornbeam (I saw a whole box of them yesterday).
They are same basic design as before (laser-cut mild steel etc) but the second batch have been done for an 8' 6" wheelbase bogie.
You still need to "dress" the outside faces with whatever external detail you require but they provide a very strong frame and a good starting point - as well as being affordable.
Ian T
Post by: hornbeam on Jan 16 2011 14:35
Great, was thinking of using them with the walsall models castings. Whats the cost of them?
Post by: IanT on Jan 16 2011 15:17
Don't hold me to it - but the previous ones were 5.00 GBP for a set of four sides (e.g. for two bogies)
Dave "The Shop" will have to confirm - but I'd guess they will be of that order.
Ian T
Post by: hornbeam on Jan 16 2011 16:54
Wow, cant go wrong for that price.  ;D
Post by: bolingbroke on Jan 17 2011 22:16
As a new member have only just seen Traininvain October post on LMS 9ft bogies. Were these progressed? I am just starting to look at construction of 57ft non-corridor stock. Already following one lead on LMS bogies but I am only at the start of the learning curve. All relevant info welcome.
