Author Topic: Axle Hung Motor Gearbox (AHMG)  (Read 22446 times)
Re: Axle Hung Motor Gearbox (AHMG)
« Reply #30 on: Sep 25 2015 11:40 »
Ralph, I make that 5.33 ratio, worse than Ian's suggestion (isn't there an annual maths test for the Technical Advisor?  ;))
Are Muffet gears good value, do they have a minimum sale value policy or similar, or are they modeller friendly? And is it a case of any colour you wish provided that it is red?
Cheers, Tim
« Reply #31 on: Sep 25 2015 12:16 »
How about this 'teaser'?
If a southbound NON-STOP  train leaves Newcastle Central at 09:30 travelling at an average speed twice that of a NON-STOP northbound train leaving Kings X at 08:30, how far has each travelled when they pass (naming the station nearest to the passing place)?
I bet Ralph will have the answer pretty quickly!
No prizes for the correct answer (and no I haven't done the calculation ... since firstly you need to find the mileage down the ECML)!
« Reply #32 on: Sep 25 2015 12:34 »
But if its a first train or virgin surely the answer is at what staion will the service be terminated and carried on by rail replacemnt bus service
« Reply #33 on: Sep 25 2015 12:40 »
But if its a first train or virgin..........
Additional info:
Southbound hauled by a Deltic , northbound by an A3!
« Reply #34 on: Sep 25 2015 14:48 »
Tim....
I know I am having problems with Glaucoma -but 64 / 12 is 5.33R... Muffet provide gears to "O" "1" and "3" model loco builders on an EACH basis if you want. Hostaform, (I call it Delrin), is only available in White. I have contacted Muffet and they will send the prices via e-mail.
« Reply #35 on: Sep 26 2015 10:03 »
I'd be interested to see that pricelist when you get it Ralph.
I'm afraid I've not had much time for this and will not be able to look at it over the weekend either. Just had a quick 'fiddle' with the idler though - which makes it more compact. The HPC main (84t) gear is 5mm wide, so would need to be 'thinned' to fit. This assumes 50mm (motor) + one boss (3mm) and gear >5mm to fit between 58mm wheelset. Will do another version with motor completely clear. Still needs playing with to find best compromise layout but will also look at alternative gear sets too.
« Reply #36 on: Sep 28 2015 09:06 »
Hot off the Mail Server we have the following:
The price per gear is as follows:
1 off       S0.7 012H             £0.29p (12 tooth)
1 off       S0.7 040H             £0.89p (40 tooth)
1 off       S0.7 064H             £1.63p (64 tooth)
VAT is in addition to the above prices.
Postage & Packing via First Class Post would be £5.00.
Best regards,
Carrie Yarrow
Muffett Gears
Tel:    01892 542111
Fax:   01892 542117
Email: carrie-yarrow@muffett.co.uk
I think they could have a few customers???
« Reply #37 on: Sep 28 2015 09:51 »
Thanks Ralph,
I'll take a look at these later in the week.
« Reply #38 on: Sep 29 2015 10:59 »
Had a few moments to spare - so quickly looked at Ralphs Muffetts 0.7MOD gearing
It works Ok but the large gear may be a bit close to the ground on the smaller wheels sets. Like the price though...
« Reply #39 on: Sep 30 2015 22:15 »
If you don't want to know about AHMG gear ratios for the HQ7P motor - then please pass quickly on to another post!  :-)
I've now looked at multiple versions of the gearing and the current version is a 2-stage one that gives a 1:9.6 ratio, which I think should be usable. I've employed a 15t (steel) pinion from Technobots and the rest are Hostaform (Delrin) gears from HPC. The cost of this combination is (for a one-off set) £16.67 but should be lower with volume.
This simple design exercise might seem quite a trivial thing to do but it's taken me a while because;
a) Most manufacturers have a limited range of 'tooth numbers' for Delrin gears available when compared to their metal counterparts. (This is why I've used HPC rather than Muffett btw Ralph)
b) For "off-the-shelf" use, I needed intermediate gears with a common axle bore and,
c) I wanted a 'full' intermediate axle (that needed to be outside the motor diameter) rather than use a 'stub' axle for the intermediates.
To be honest, at one point I thought I might not find a usable combination but I eventually tried a mix of MOD gear sizes and this helped. So the first train is 0.5 MOD and the second is 0.7 MOD.
Anyway, (all) we need to do now is find a simple/affordable way to mechanically fit & mount my chosen components into some form of workable 'gearbox'. I'll have a go at this next week and assuming that I can come up with something, I will then build a prototype to test. Please don't hold your breath....
« Reply #40 on: Sep 30 2015 23:31 »
This all sounds very positive ian, am watching with great interest, thank you.
For what it's worth I do think you are right to suggest supporting the idler shaft on both sides. Dave Lowe used some natty little PTFE lined top-hat bushes for his Peak gearboxes; they may do the trick for this intermediate shaft and take up little space.
Keep up the good work, Tim
« Reply #41 on: Oct 01 2015 09:23 »
Hi Tim,
I've had a very quick look for PTFE steel bushes and have found several sources and more importantly - they seem to be made to standard dimensions (which I now have). Without hunting around, they retail at about 50p each, so are affordable.
A very useful suggestion, thank you.
« Reply #42 on: Oct 01 2015 14:15 »
For those who are poor and penniless amoungst us...
Being brought up in "Sanctions" does tend to amplify the cheapskate in my mind!!!
It should work at wheels of 3'7" although the gear sizes may be a bit "tight" on the Motor and the Bull gears but it is £13.57p cheaper per axle. Ratio is (as far as I can see...) 1:17.77R
« Reply #43 on: Oct 01 2015 16:30 »
Make and modulus and material needed please Ralph, don't drop tantalising morsels without the goods!
If they are cheaper than Ian's solution by £13.57, then are you saying the whole lot costs only £3.10??
I struggle to believe that, even from a thrifty chap like you!
« Reply #44 on: Oct 01 2015 18:04 »
I thought I was the one supposed to be going blind? The Gears are Muffet 0.7mod made from Delrin -as in the price list above. I *DID* say that they might be having a few orders???
