Author Topic: Painting G3, our size, models  (Read 3578 times)
« on: Apr 08 2017 18:01 »
I've just been reading Ian Rathbone's book on painting and I am wondering if my Iwata is going to be man enough for the job or maybe yes but with a bigger paint reservoir.  I have painted all of my wagons with a rattle can but the next project, a horse box, will need a colour not found in a rattle can  :).  How have other members managed?
Re: Painting G3, our size, models
« Reply #1 on: Apr 08 2017 18:18 »
I use the mixing centre at B+Q. I have yet to find a PAINT that is not there. However the system cannot produce LAKEs, so brown lake or crimson lake are not available. (sigh).
« Reply #2 on: Apr 09 2017 09:08 »
That would sort out the colours but how do you apply it, brush or spray?  If spray, what pressures are you using measured at the nozzle?  I know that this would not apply to all equipment but it would be a help to get me going.
« Reply #3 on: Apr 09 2017 13:18 »
A slightly different question here.  Does anyone think that 14ml of thinned paint would cover a horsebox?  Before I go for it, I'm trying to sort out paint quantity which would determine which sort of air brush I would use as they have different sized cups.  The smaller cup fits on the side of one of the air brushes but the large container fits underneath it's air brush.  The mahogany that I have is of the earlier 'Cherry' variety and I don't want to waste any by mixing too much paint.
« Reply #4 on: Apr 09 2017 14:08 »
I always use a brush! I was never brought up on air systems and I have only used them a couple of times.
« Reply #5 on: Apr 09 2017 19:41 »
Hi Jon,
Assuming it is a dark shade over a lightish primer, you should have plenty for two or perhaps three light coats.
If a light shade over a dark undercoat, you may need more coats.
I usually charge the reservoir on my 25 litre air tank to around 40 psi.
« Reply #6 on: Apr 10 2017 08:52 »
Thank you for that.
It will be Mahogany over red oxide now.  I'm interested in your spraying pressure.  When you say 40psi at the tank what is the pressure at the nozzle of your spray gun/airbrush and at what ratio do you thin your paints, assuming they are enamels?
« Reply #7 on: Apr 10 2017 09:40 »
The nozzle pressure is same as the tank output (I never exceed 45psi and once it drops below 38psi, I recharge the tank (one charge of a 25L tank will easily coat a loco.).
Thinning is difficult : It depends upon the consistency of the original : Some I find to be quite thick and others very thin.
If it is fairly "runny", I would start with around 10%  thinners and do a test spray, adding in 5% steps.
Rarely do I need to exceed around 30%.
« Reply #8 on: Apr 10 2017 15:12 »
Thank you, John, you've been very helpful.  One last question though, what spray gun/air brush do you have?
« Reply #9 on: Apr 10 2017 19:51 »
It's a Badger which I have had for at least 30 years!
I think, from memory, the model is "200", which has both a paint jar and a small external paint reservoir.
« Reply #10 on: Apr 11 2017 09:54 »
I have a DeVilbis which I have never used and would be happy to find it a good home.  Maybe somebody would care to comment on these?
« Reply #11 on: Apr 11 2017 12:57 »
Devilbiss are / were a well respected brand too - they used to be sold under the 'Aerograph' name, with models such as the Sprite (my dad has one of these) and Super 63.
Which model have you?
The key thing for G3 is the size of the paint cup - even for a 4w van, the typical paint cups (around 5-10 c.c.) are simply too small. I bought a secondhand Aerograph 63 (which has a bigger cup than the Sprite), but still got frustrated with the need to top-up half-way round a wagon!
The Badger 200 (mentioned by John C), and the Aerograph Sprite Major both have the ability to use decent sized bottles - and will be on my shopping list when I get back to painting again.
« Reply #12 on: Apr 11 2017 18:57 »
This is the kit that I have and the set up on the left is the one that I have used in the past.  The set up on the right, I've yet to try as it has a different air/paint control button but a huge paint reservoir.
« Reply #13 on: Apr 12 2017 18:05 »
Sorry Andy - my mistake.  Its a Badger B200/3 that I have.  Looks like Jon has all the right equipment anyway.
« Reply #14 on: Apr 13 2017 18:04 »
I just have to learn how to use it now, that's all   ::)
