Author Topic: 1361 battery pack  (Read 1010 times)
1361 battery pack
« on: Oct 29 2017 16:58 »
Evening,
I’m in the final stages of re-building a GRS 1361 tank and will be fitting with a train engineer receiver. I’m wondering what battery packs have others used and how have you laid out the RC as there isn’t a huge amount of space,
Simon.
Offline keith Bristol
Re: 1361 battery pack
« Reply #1 on: Oct 30 2017 21:42 »
Hi
I used twelve cells in mine in two circular stacks of 6 which are connected but nit sealed as one to bend though square whole in base of boiler. I then put revo between frames behind the cylinder and then the sound card in the bunker with switch and charge socket. The speaker is in smoke box.. Fiddly but doe able...
Happy to help.. I have pics somewhere.. It was running on Warton Road at Leeds at the weekend
K
« Reply #2 on: Oct 31 2017 09:33 »
Hi Keith
do you know if anyone took any pix of Warton Road at Leeds which I could use for the G3 Newsletter?
tx
« Reply #3 on: Nov 01 2017 07:35 »
Simon,
Of possible interest are the NiMH AA cells I noted at IKEA the other day.  They are about 2400 mAh and only about a fiver for pack of four.  They are not tagged cells of course, so you would need holders.
« Reply #4 on: Nov 02 2017 17:13 »
Thank you for all the help. Will look into it and let you know how it goes,
Simon.
