Author Topic: Wheels : Words of Caution.  (Read 633 times)
« on: Feb 26 2019 09:23 »
For a couple of projects I ordered 20 x W6 pattern driving/coupled wheels from the 2.5 Assocn and relied upon their catalogue description as published on n25ga.org .
They are listed as having crankpin between spokes and without balance weights.
Last night I unwrapped the wheels and found they have crankpin inline with spoke and do have balance weights!
They have W6 cast into the boss, so are not a selection error by Brian K (their very helpful castings officer).
I will now have to sort out what is to be done.
So, if you are thinking of ordering using the n25ga.org website descriptions, I suggest you ask Brian to check and confirm description is correct.
Re: Wheels : Words of Caution.
« Reply #1 on: Feb 26 2019 12:03 »
In real life and the Sanctions... If the wheel was remotely the right size it was used. This lead to some strange  lopping and hopping and such locos moved at low speeds - but they did move...
The Scullon Disc wheel was tried by several railways.
« Reply #2 on: Feb 26 2019 12:13 »
That must have been an interesting period for Rhodesia Railways!
(for those who don't know, Ralph was brought up in Southern Rhodesia during UDI ....the era of Prime Minister Ian Smith's rebellion.....when Britain enforced sanctions which eventually led to the creation of independent Zimbabwe and President Mugabe).
Offline Baggo
« Reply #3 on: Feb 26 2019 12:49 »
Hi John,
I'm sorry that you have had a problem with the wheels. I'm sure Brian will give you a full refund if they are of no use to you.
I thought that the mistake in the description could well have been mine but that particular page was carried over from the original website done many years ago by the late Gerald Chandler. I just copied it when I built the new website.
I will alter it of course to correct it but it is best to check with Brian before ordering as you suggest.
Member of North West Leicestershire SME
Secretary National 2½" Gauge Association
« Reply #4 on: Feb 26 2019 13:04 »
Hi John,
Thank you for your response.
Shall be contacting Brian this evening to see what he proposes.
The person for whom I am building the locos has been informed and he needs to decide what substitutions to make.
The only alternatives to obtain absolutely correct wheels appear to be custom orders either through Mark Wood or Slaters. He may be willing to accept the Alan Headech wheels type 7518N (the crank pin position is inline and not between but at least there are no balance weights).
