Author Topic: GWR City class loco  (Read 2252 times)
GWR City class loco
« on: May 04 2019 14:15 »
 Considering the wheels for the City I could not find a supplier of GWR 6’ 8” plain drivers, I could buy crank boss ones and cut out crank pin area but by the time you pay for a set of drivers and then rework them I thought it just as easy to make them and save a few quid for other items required.
This the test wheel, and I am quite pleased with it!
Re: GWR City class loco
« Reply #1 on: May 04 2019 15:38 »
Very nice Mike.  So that is CNC milled from solid ... aluminium?
« Reply #2 on: May 04 2019 16:34 »
Yes 1/4" thick ali with a 3mm end mill so you have a slow feed as ali is very sticky with small cutters, lots of suds!
I will have to order in some 4"dia  BMS for the tyres, if I cut out the centres they should be big enough for the tender tyres?
« Reply #3 on: May 05 2019 15:50 »
Researching details on the City I found a very nice image of an original build, and an interesting comparison with the rebuilt version.
I prefer the original less busy, cleaner lines, and no top feed.
« Reply #4 on: May 11 2019 10:03 »
Advice sought regarding powering the City, I have a Mabuchi motor rated at 6-18v and am considering using a lead acid battery which will fit well in the tender and I would think will have more power than NiCad’s. What amp range would this kind of motor pull under load?
That way I can add specific weight to the loco if needed i.e. front or back.
« Reply #5 on: May 11 2019 18:17 »
I have not used lead acid cells in a model loco but Ralph is keen on SLAs and will no doubt give some advice.
I use Ni-MH cell packs rated at 2.3Ah which power either Buehler or Mabuchi motors with a 24V max. rating. I find that a 16.8V nominal pack (which fully charges to around 19V) will run for at least 2 hours with a reasonable load in tow, so the average current drawn would be around 1A.
I now fuse my locos 5A and have yet to blow a fuse.
 On the advice of Brian Jones (supplier of Mac 5 ESC), I fitted my first-built G3 loco (LNER/GC N5 0-6-2T) with a thermal cutout rated at 1.6A and that has only once tripped, when the loco stalled.
Photos of the "guts" of Calcutta's tender below : Mtroniks Viper Loco 10 HV esc and "MyLocoSound" card included.
« Reply #6 on: May 11 2019 21:47 »
Mike, look at the Mabuchi website which will tell you certain performance data for each type of motor.  Beyond these basics I find Mabuchi a pain in the neck, as they seem very secretive and selective about who is permitted to register on their site to see further info!  Hardly a good business model... I’m still awaiting “approval” after several days!  Moan over, I support the use of sealed lead-acid (SLA) batteries, but partly because their weight over the driving wheels gives good tractive effort.  So without much weight in the loco you may suffer considerable wheelslip unless very carefully controlled!
Rgds, Tim
Thank you,
Facebook.com/AppleTreeRailway/
« Reply #7 on: May 12 2019 14:36 »
John and Tim thanks for your suggestions, I had thought about weight distribution over the whole loco, and as there are only four drivers you may be right to get maximum weight over them. I think some experimentation once the chassis are complete is the way forward.
« Reply #8 on: May 16 2019 15:16 »
Considering the comments and suggestions regarding suspension / compensation in earlier posts, most applied to six coupled inside framed locos.
The City has outside frames and they need to be modelled faithfully, as there was no room for gear between inside and outside frames, that meant introducing inside axle boxes for springs / beams to bare on thus doubling friction and restricting movement.
The obvious solution to modelling outside axle boxes / horns was to make them work, the chassis now has sprung axle boxes on all four driving wheels
The motor / gearbox is mounted on a slotted cross beam between the inside frames allowing the module to move in the vertical plane and pivot in the horizontal plane. This combination should keep all four drivers in contact with the rails thus providing traction?
The motor and gearbox were made from component’s found on e-bay total cost £18.98.
« Reply #9 on: Jun 02 2019 10:48 »
Progress on the City, the wheels were machined from ¼” ali plate with steel tyres they are fixed to axles through extended hubs with grub screws, the axles have squared ends for quartering and the cranks are fixed to axles with countersunk socket screws then faced flush with cranks. The bogie has narrow inside frame for space for light springs on axles to allow wheel side play, the outside frame is just cosmetic the very nice axle box castings are from Walsall.
« Reply #10 on: Jun 15 2019 16:38 »
The boiler smiths have been hard at work rolling and riveting, also the lovely plates have arrived from Guilplates. Much to my surprise the bottom radius of the name plate matches the top radius of the splasher, sometimes you get things right first time!
« Reply #11 on: Jun 15 2019 18:37 »
Taking shape nicely, Mike.
What material have you used for the front of the firebox....is it steel?
Guilplates do a good job .... mine were a perfect match for the Bulldog splasher.
I don't recall ever having seen an outside framed GWR 4-4-0 in G3, so "Truro" and "Calcutta" may be "firsts".
At the moment I am held up waiting for a spring casting to arrive from WMI ....... for some reason I was sent only three originally.
« Reply #12 on: Jun 16 2019 10:54 »
Yes the smokebox door is steel only because I have a bar of 2 1/2" steel, the door is working to give access to the boiler space for battery. It would be fun to run them double headed when finished?
« Reply #13 on: Jun 16 2019 12:36 »
Quote
Ooh, my model doesn't rise to that level of sophistication!
I cast my door and foundation ring in whitemetal (in fact I cast a batch of five doors..... hopefully I shall eventually add a 43XX Mogul, 31XX Churchward Large Prairie and a "Saint" to my GWR collection).
My batteries (in fact everything except motor) are in the tender.
I shall be glad when I have got a coat of primer on it.....the nickel silver, in particular, is badly discoloured from the effects of heat and flux.
Truro and Calcutta as a "double-header" would be a sight to behold....... possibly at the Ampthill GTG?
« Reply #14 on: Jun 16 2019 14:15 »
You mentioned plans to build a Saint in the future, thought you might like to see my efforts in G1 which was built to Swindon drawings with the idea to coincide with Didcot’s rebuild, but they delayed for a year and thankfully celebrated completion early this year. A wonderful day!
