Author Topic: Battery power  (Read 992 times)
Re: Battery power
« Reply #15 on: Sep 27 2019 08:12 »
Jon,
If your Slater's box is marked GBG3-50C, then it is the same unit as in my J39 and to be fitted to the 2251.
It will not turn very fast on a 9V supply (I have checked it using a large non-rechargeable EverReady PP9 which is putting out 9.7V) since the motor is rated @ 24V. I would suggest 14.4V nominal (i.e 12 x AA Ni-MH) for your application.... at 50:1 I would estimate it should give in the region of a scale 40mph.
Offline Jon Nazareth
Re: Battery power
« Reply #16 on: Sep 27 2019 08:31 »
I've measured the case of my motor and it matches yours so, it can be assumed that they are the same model.  I'll phone Slaters later on and check to see if it is actually a 24 volt motor.
On another tack.  I've remembered that I have an MSC, 25:1, 12 volt Crailcrest motor and 1/4" axle gearbox.  Would this be okay to drive Lion?
Re: Battery power
« Reply #17 on: Sep 27 2019 08:43 »
Jon,
If the Crailcrest unit fits, then I see no reason why it shouldn't work.
With a 12V motor, 9.6V nominal (i.e. 8 x AA Ni-MH 2300mAh) should work very well.
Re: Battery power
« Reply #18 on: Sep 27 2019 09:07 »
Thanks, John, it looks as if we may be getting up some steam after all.
Re: Battery power
« Reply #19 on: Jun 14 2020 09:02 »
Well, all went well and here's the finished loco.  It has only run up and down the short track that I have but seems to go along okay.  When we are out of this mess, it will be nice to see it on a proper track at a GTG.
Re: Battery power
« Reply #20 on: Jun 14 2020 09:08 »
This should have been with the above post
Re: Battery power
« Reply #21 on: Jun 14 2020 10:40 »
You have made an excellent job of Enigma; I also like your coal wagons, should make a pleasant sight to see them working as a train.
