Author Topic: laser cutting  (Read 2963 times)
Peter D Hingley
  • Guest
Re: laser cutting
« Reply #15 on: Nov 08 2011 09:51 »
The  basic    problem  with  both laser   cutting and  water  jetting is that the   firms   only  want to  accept  patterns  as CAD  files.     To the  non -  computate  like myself  this is an impossible    obstacle   and much though I would like   to  use  these methods   it would take me longer to learn  these   monkey  tricks than  to   make the   things for  myself !
                                                  Peter D Hingley
Offline andrewfoster
Re: laser cutting
« Reply #16 on: Nov 10 2011 17:44 »
Peter -
For simple parts there's not a great deal of work in preparing a CAD drawing if you have a good detailed sketch, and you might easily find someone (probably in this forum!) who would do it for you as a favour or for a modest price.  The laser shop only needs the bare drawing data in a commonly used format, and as long as it's accurate and designed with some understanding of laser cutting, they can make the part.  It's a quick process, but the cost of small quantities may be off-putting.
Andrew
Offline keith Bristol
Re: laser cutting
« Reply #17 on: Nov 10 2011 20:24 »
Peter Andrew
Please contact me if you require a CAD drawing done for laser cutting.. so long as its not a complete carraige side!
Keith
