Author Topic: Closest to Scale bricks  (Read 1250 times)
« on: Sep 17 2012 23:42 »
Need to get the wife away from the telly and on with something usefull . Out there in the big bad world , Who does the closest to scale bricks please ?
Re: Closest to Scale bricks
« Reply #1 on: Sep 18 2012 07:58 »
Hi John
Having just hand scribed many many bricks for the viaduct I can safely say it sends you doolally. The end result is good though. I used Slaters 4mm planking plasticard A4 sheets. All I had to do was scribe the vertical or upright markings so you could create your own unique brick pattern. Each sheet cost £1.20 as opposed to £7.00 from GRS. The big headache was the scribing though and as there was a cost saving I decided to plod on.
See the blackgang viaduct section on the forum.
Offline Derek King
« Reply #2 on: Sep 18 2012 09:13 »
Mark's idea sounds good, but if you want to go the whole hog try www.minaco-uk.com who have a whole range of 1:24 building materials including individual brick slips. £4.99 for pk 250, but appears to be on offer at the moment - buy one get one free!
Derek.
Offline Derek King
« Reply #3 on: Sep 18 2012 16:53 »
After my last post I realised we had covered this subject before under "Help required re brickwork sheets" - surprised nobody else had picked this up!!
In that string it appeared the sheets from South Eastern Finecast were the best buy.
Derek.
« Reply #4 on: Sep 18 2012 17:50 »
Whatho John
try these places:
Miniature Scene, York:
http://www.miniaturescene.com/shop/category_14/Bromley-Craft-Realistic-Brick-and-Stone-Effect-Products.html?sessid=zsv7hfeRjNdh0nnGKDRiaSooK0dIKqY2ZNXTzx1qZvgn5VmTAQXX165Mbfptr5sK&shop_param=cid%3D%26
They do all types of things for 1/24 scale including embossed plastic and pronted paper bricks, plus a system where you smear on the plaster or whatever it's called then press a stencil on - very realistic
4D Models, London
http://www.modelshop.co.uk/
They do embossed plastic bricks in 1/24 scale plus printed card and paper bricks
« Reply #5 on: Sep 18 2012 23:43 »
Hello Ian & All
Thanks for help and comments , Had a bit of a look around , Not sure we want to go down the stencil route just yet . Have ordered some brick slips to have a mess about with and see how we get on with them . Building we have in mind is the weigh bridge house at Birchenwood Coal and Coke ( Hope that I have spelt it right ) Just north of Stoke on Trent . Part colour view in Rodger Siveter's industrial steam book . Also found an old egg end boiler to measure up and stick on brick pillars for a water tank .
