Track and Signals => Track Construction => Track-laying => Topic started by: hornbeam on Jan 02 2014 15:55
Title: Platform clearance
Post by: hornbeam on Jan 02 2014 15:55
Hi all,
Is there a standard for the distance between rail and platform edge? I've got some GRS platform sections, and want to know what distance to put between the platform and the track. I don't want it to look like passengers have to jump nor do I want stock hitting the edge. Platform sections are 60mm high.
I would normally test and see, but as I'm getting a custom curved point made I need to get it right.
Title: Re: Platform clearance
Post by: 454 on Jan 02 2014 16:26
Hi Hornbeam
Apologies in advance for joke.
Get a sound card & programme it with "Mind the Gap" like on the tube in the West End.
End of joke.
Serious stuff:-
The straight is easy to deal with but if the curve is anything that is a bit sharp, watch out since visiting stock will hit it as you cannot cater for all types. You must be on the generous side for a curved platform clearance. Bogie carriages being prime examples & bent out footsteps & footboards. Oh, & brake levers on wagons. Yes I have had to repair many due to "scale" clearances. So be generous.
With a bogie carriage you could scribe a line of the locus of the edge of the footsteps onto the baseboard & use that as your starter for ten.
Hope this helps
454
Post by: hornbeam on Jan 02 2014 16:34
Ha! Mind you I'm not planning the blue platform light that the underground now have owing to the new s stock. Thanks, platform will be straight with enough space after the curve to allow coaches to straighten off the curve.
Post by: AllWight on Jan 02 2014 20:12
Trick to get the platform edge correctly sited. Use the longest bogie vehicle you can use and temporarily attach a pencil to one end and the mid point of the body. Run it through area the pencil will mark on the base board the closest you dare go over the given length area if the platform.
Title: Re: Platform clearance .... urgent feedback required!
Post by: John Candy on Jul 19 2015 21:01
I am about to fix the platform facing wall for my high level branch terminus.
A straight platform 13 ft long made of resin castings of stone pattern cast from Jigstones moulds.
How much clearance (rail edge to platform edge) is needed for outside cylinder tender locos.?
I have in mind G3 SCALE locos (not over-scale 2.5 inch beasts) such as the GRS GWR Manor, Kingscale Britannia also the GRS GW 45XX "Prairie" tank.
Currently my only locos with outside cylinders are small tank locos but I don't want the cylinders of visiting locos "walloping" the platforms!
If you have one of these locos, would you please measure the maximum clearance required (including any deflection / "waggle" resulting from lateral slack in the wheel bearings).
Thank you.
Post by: IanT on Jul 19 2015 21:45
Hi John,
I looked at this in some detail when designing my modular track system. I've extracted part of my notes on the subject that you might find useful, which I think was published in the NL at some point. I also referenced Alan M's observations on the subject if you have the NL in question.
"In the September 2010 Newsletter (No 82) Alan M's guidance on 'track clearance' was re-published (from an original article published in 2002). I thought it would make good sense to use CAD check my initial 'modular' model against Alan's recommendations. I therefore drew a twin-track (with a 4500mm outside radius at 160mm centres) and 'placed' two BR carriages on it (as per Alan's original practical experiment). I found that the two carriages passed but only just. I measured the passing clearance between carriages at just under 12mm and of course this is a static model. Stock may sway sideways at speed.
I then had a good look at NEM standards (NEM103 & NEM112) to check their recommendations in this area (they can be 'googled' if you wish to read them).
The NEM use three different 'maximum' carriage lengths (A, B & C) plus tables, to calculate the value of an expression 'E' which gives the clearance. In NEM terms the normal clearance of a straight track is called 'B1' and on a curve they define the required clearance as being 'B1+2E'. What NEM does not give is the formulae they have used to calculate 'E' but I found this in one of the Spur II standards. Essentially, it takes the radius of the curve and the distance between the two bogie pivot points to arrive at the value 'E'. It also assumes that the vehicles fit the three standard 'max' sizes defined by NEM103. Armed with this information, I built a simple spreadsheet to calculate 'E' for the proposed G3 standard modular curves.
Now clearly the A, B & C sizes in the NEM standards are for Continental loading gauges but I noted that a BR Mk3 sits between the A and B lengths. To simplify matters, I therefore decided to use NEM size 'B' as my norm for these calculations. A summary of the results are shown below.
Radius of Curve (mm)   Clearance (B1 + 2E) mm
1500   258
3000   208
4500   192
6000   184
7500   180
Based on these results, initially I felt that we should publish a new standard ("M02") to give the required clearance for each of the standard curves proposed in M01. Indeed I wrote a draft M02 on this basis. However, on thinking about it, I decided that the recommendation could (and should) be simplified.
The first simplification is that twin-track modules should not normally be built at the 1500 & 3000mm radius, at least if you want to run long bogie stock. I feel that these should be defined as 'single track working' in the standard. This left the other three radii with (calculated) recommended clearances of between 192 and 180mm. Again, I feel that this could be simplified (and given that there is already some tolerance in the calculation) that a single clearance of 185mm should be set on all three radii.
Having reached this conclusion, I was left with the issue of the "transition" module, which would enable the track spacing to move out from 160mm to 185mm. NEM give this as a distance of >15xGauge (952.5mm in G3) but a single 900mm module would be sufficient. However, this transition module would be required on both entering and leaving any twin track curve. To be clear, this is a 'clearance' widening transition, not a 'transition curve'. "
Hope this helps!
Post by: IanT on Jul 20 2015 10:23
Re-reading this (this morning) it's occurred to me that many people looking at this post may not easily understand the measurements being used and how the various factors inter-relate. So I should probably try to explain them a bit further for anyone wanting to look at this in  more detail.
Early on I refer to 160mm "centres". This was a reference to a 7ft 'way'. It's the distance between the two track centres. So taking 63.5mm (the gauge width) from 160mm, the way is 96.5mm (e.g. 7.15 scale feet). Other clearance measurements given later are of the same nature (the distance between track centres).
In practice, a platform on the outside of a track curve needs to be sufficiently clear such that the 'worst case' vehicle does not strike it. In this case the "worst" vehicle is the longest one with the shortest distance between the bogie pivot points - as this causes the greatest swing 'out' of the vehicle ends.
For a platform on the inside of a curve, the worst case vehicle will be the longest one with the bogie pivot points nearest the ends, as this give the greatest chordial height e.g. the centre of the vehicle will swing further 'in' to the curve.
So in practice, I think that the clearance for a straight platform can be quite near scale loading gauge but that care must be taken where any curved track is involved at entry or exit points. For platforms on curved track, then I think half the suggested clearance given in the table would be fine but might look a little wide. Any transition between straight and curved platform sections should also be considered and I'd probably err on the side of safety.
As others have mentioned, a simple empirical method of setting the platform out would be to run the longest vehicle through the section with a few objects placed along the track to see if anything gets hit.
But if you need some method of calculating the required clearance, then the method outlined is probably the one to use, as there are a number of variables and some assumptions have to be made.
As a matter of interest, this work was done some years ago now and I eventually decided that (for my modular track) I would not use transitions (in the sense of moving between scale 'ways' and running clearances for curves) but simply use a fixed 185mm between track centres for all my track. Not prototypical but it looks good enough and is much easier to build and assemble.
