Buildings, Structures and Scenery => Buildings => Topic started by: John Candy on Dec 19 2021 15:05
Title: The cure for a thirsty Coal Tank!
Post by: John Candy on Dec 19 2021 15:05
Now (with the fresh addition of a Coal Tank) having 5 LMS locos, they need their own watering hole, instead of filching from the GWR supply!
The answer is a 2000 gallon LNWR cylindrical tank.
The basic patterns (prepared from drawings in "LNWR Portrayed", a PECO publication which has been on my bookshelf for 40+ years) have been 3D printed.... It took 10 times longer to print than it took to me write the SCAD files!
I have not decided whether to make moulds and cast a few more (in resin) or to simply print more when/if  required.
The main components are in the photos attached (there are more details waiting in the print queue).
Title: .....now a LNWR water column
Post by: John Candy on Dec 20 2021 20:53
I have just uploaded the SCAD files to print the familiar LNWR water column.
The column is shown complete in the attached screenshots but, for ease of printing, there are separate files for the main pillar, the "cap" and the outlet spout.
You will find them at:
http://gauge3.info/openscad/LNWR_water_column_1.scad
http://gauge3.info/openscad/LNWR_water_column_2.scad
http://gauge3.info/openscad/LNWR_water_column_3.scad
UPDATE : March 2023
The 3D print directory and related files have been amended and moved to www.gauge3.info
All files are now supplied as .STL (not .SCAD)
The "bag", control rods, levers, etc. you can add from brass, etc.
The files for the LNWR 2000 gallon cylindrical water tank will be made available in due course.
Title: Re: The cure for a thirsty Coal Tank!
Post by: John Candy on Dec 21 2021 20:27
This what you have after printing the three SCAD files in the previous post.
The material is PLA and the Snapmaker A350 did its stuff.
The main pillar was printed vertically, without any need for temporary supports.
It remains to add the control rod and lever (brass) and the "bag" (I used shrink tubing for my GWR water cranes).
A spray coat of grey primer and some weathering will finish the job.
These columns are (were) 17ft high and look massive when placed by a loco.
Title: LNWR water column drain
Post by: John Candy on Dec 23 2021 04:13
The file for the drain cover (with brick surround) for the water column can be downloaded from
http://gauge3.info/openscad/LNWR_water_column_4.scad
UPDATE : March 2023
The drainage arrangement for the cylindrical water tank is different and will be released when the complete set of files for the 2000 gallon tank are made available for downloading.
Title: LNWR water tank drains
Post by: John Candy on Dec 28 2021 00:33
The drainage basin for the 2000 gallon cylindrical tank.
This is for a double outlet tank but can be easily adjusted for single arrangement.
(https://i.ibb.co/W6fKs54/LNW-tank-drain.jpg) (https://ibb.co/W6fKs54)
P.S. It is currently printing and is predicting a print time (on the fastest setting) of 15 hours 28 mins.
Post by: John Candy on Dec 28 2021 18:02
In the end it took 14 hrs 30 mins to print!
I think I will use it as a pattern for a mould and cast extras in resin, rather than print more.
(https://i.ibb.co/qrMnfwh/wtb3.jpg) (https://ibb.co/qrMnfwh)
Title: Going up ...... water tanks, signals, etc.
Post by: John Candy on Dec 30 2021 07:20
A quick and easy one!
Takes just 45 mins to print at medium resolution (would have taken just 24 if on the fast print setting)and gives you a ladder 310mm in length.
It may look flimsy but is far stronger than it looks.
PLA is a resilient plastic which can be distorted and will spring back to shape.
If you knock a brass etched ladder it will stay bent (or likely still have a bit of a kink when you straighten it).
Even if it were to break, at a few Pence each, you can keep a few spares in the drawer.
Download http://gauge3.info/openscad/ladder_for_signals_etc.scad
UPDATE : March 2023
