Optimum Axle Loading / Loco Weight?
Started by John Candy, Aug 13 2010 11:18
Charles,
Sorry the tablets took longer to work and I spent some time "learning how to move again!" Ok this is the rough doodle. It shows the two sets of toothed belts fed from overhead. I have used the MFA 919D8 cog as my guide -you can probably source similar locally. There will have to be a slipper tensioner to the belt (either a springy brass strip or a sprung nylon shoe).
http://www.cabbagepatchrailway.co.uk/mls/charles3.png
I have changed the method of the gearbox. The vertical motor now works directly onto the worm and the rest is as above. I hope we are getting there!!! This is not "labour" as far as I am concerned -this is fun!
Charles,
I am going to drop a line to Tony Walsham -who is in your part of the world.
Just back from holiday (and suffering from an eight hour jet lag) so I haven't read right through the detail of this thread and to be honest I'm feeling just a tad tired. However, as an observation this is a fully "coupled" engine (I assume) and I would have thought that driving a single axle would be a much simpler way to adapt the engines power source (than using an arrangement using two worm and/or belt drives). I may have missed some subtlety along the way though.
Dave White runs a very simple arrangement on one of his (steam) locos along these lines, with a large motor in the boiler/firebox space that directly drives a small chain (6mm?) drive down to a simple geared axle (the gears used for the axle gear box (90deg drive) are angle grinder spares - at about £10 per set). There is some give in the chain drive that helps simplify the suspension side of things (e.g. the motor is fixed, the driven axle is sprung as normal). The chain sprockets also provide a slight reduction in the gear ratio.
When I last saw this engine (at Ampthill), David had not 'boxed' in the chain drive but intended to do so by making a false back-head with scale fittings etc. The engine seemed to run very well and pulled a good load - although I don't remember the motor size/spec he used.
Just a thought.
Ian T
Good morning Charles,
Still a bit groggy this morning but hopefully my internal clock will adjust a bit through the day.
The chain sprockets required for a small 6mm timing chain will normally fit inside a 2.5" frame but if you are tight on space (width) then a timing belt might be a better solution for you.
If there are further problems with fitting the axle/gearbox sufficient to give the required step down ratios, then an alternative might be to place a further (spur) gearbox inside the boiler (i.e. between the motor and the chain/belt drive). Then the final gear ratio would become less of an issue as (worst case) it simply needs to move the drive through 90 degs.  In other words, if there is not sufficient space between the frames, then use the ample space in the boiler/firebox area.
It would introduce another level of complication but still retain most of the advantages of using a single axle drive (in terms of springing and independent axle movement), so would be worth considering.
Good luck with the build.
For something "out of the scrap box" your engine is looking very tidy Charles!
Nice work - looking  forward to seeing progress.
They say "a picture paints a thousand words" and it certainly does with your engine.  Very nice Charles.
1) Are the buffers self contained?
2) What are "x" pins? Does "x" mean "it was" a pin i.e. ex pin? Or is it some Oz term for a pin size?
If that has been made from what is out of the scrap box I would love to see what was made that was not scrap?
Keep up the momentum with this build Charles. Pity it's not a live steamer.
Charles
When I questioned "are they self contained buffers" I probably did not explain what I meant really. To me a self contained model loco buffer is one which fits on the buffer beam & does not penetrate behind it when the buffer is pushed inwards. A lot of constructors tend to put the buffer head on a shaft which pokes through the beam & sometimes can be seen when operating. But is often a better proposition when there is risk of fouling with the loco frames. The back of the buffer is flush & has a plug which holds the spring & shaft/head all together in one unit.
So on that basis is yours self contained or does it poke out at the back of the beam?
I'd be very pleased with that drawhook too Charles - for someone who "knows nothing about locos" I think it's clear that you do have some excellent workshop skills.
Keep posting the photos, very much enjoying them.
Very nice buffers Charles, that second pic shows better detail.
jamiepage
Superb work, Charles. The photos are really interesting.
All the best
Jamie
