Basic tram engine
Started by hornbeam, Dec 26 2010 20:18
hornbeam
Good evening,
here goes. Im looking at building a live steam Loco based on the Y6 tram as I have a GRS resin body on the shelf. Now I only have access to a bench drill, hand tools and a vice. Im planning on getting the wheels, steam motor and frames from GRS and the boiler and fittings from Roundhouse or pick up one from Accucraft. ( I know its not going to be very scale inside!). So a few questions:
what is the distance between frames on the GRS locos?
are the steam motors any good, and how are they fixed to the frames?
My plan is to mod some GRS frames and coupling rods as I guess this is the best option for me?
I appreciate this whole project may look very poor comparing to what some of yoiu guys can do  :-[
I adapted three of the GRS Y6 bodies to run on re-gauged "Cheddar" chassis.
Cheddar Steam is now defunct but if you can lay your hands on a secondhand 45mm gauge "Iver" (they crop up on Ebay occasionally...or GRS may be able to point you in the direction of a 45mm example...the 32mm gauge type will be of no use) they provide an excellent basis for the conversion.
The chassis has outside oscillating cylinders and is a powerful and very controllable design with ready-fitted R/C servo motor. When new they retailed at around 400GBP so a used example should prove more economical than purchasing a boiler, steam motor and all the associated gas firing parts.
The "Iver" design is now marketed by Stuart Turner but at a greatly increased price.
hornbeam
Thanks John,
what was involved in re-gauging it?
After removing the boiler and fittings, I sent the three chassis off to a model engineering company to be re-gauged (at total cost 700GBP for the three).
The procedure involved cutting through the axles to remove the wheels (the side-rods are retained by circlips and were removed first) the intermediate frame spacers and the outer frame ends/spacers are removed (screw-fitted) and the steam supply pipe between one cylinder and the steam manifold control block is cut.
The outer (end) frame spacers are re-drilled/tapped to required spacing and new intermediate brass spacers fabricated.
A sleeve is soldered to extend the the cut steam pipe to suit new spacing.
The original wheels were retained and the steel axles were sleeved to the correct gauge and drilled and pinned to the maintain the quartering.
I was not entirely happy with the re-cycled wheels and currently they are back with the company involved for new wheels to be fitted.
It would be possible to do the conversion at home by re-using the original wheels, the most difficult part would appear to be quartering the wheels with absolute precision.
A couple of photos of one of the chassis prior to conversion are attached together with one of the locos in the final GER livery (the other two are in LNER livery).
#4
Well...
Greetings from Kitchen Sink Engineering
I tend to do things the easy way.  You require two Unit Steam Engine kits at roughly £30 each. They use Silicone tube for plumbing. These can be assembled with hand tools by my 11 year old son. They require 2 to 3 BAR pressure with no superheat. The boiler can be simply soldered together on a gas cooker -or better with a MAPP using bottle torch. The drive to the wheels is via lengths of chain and there is a chain between the two drive axles -thus the quartering becomes visual rather than accurate... (ie keep filing the holes into slots until the wheels go around).
Have a look here: www.cabbagepatchrailway.co.uk/heilmann.html and here: www.cabbagepatchrailway.co.uk/metrovick.html
SAFETY NOTE by Admininstrator: Pressure vessels and steam must be treated with respect since they have the potential to injure. You should not follow advice given in this forum unless you have the experience necessary to assess the risks involved (particularly with respect to boiler manufacture) and possess the necessary skills and knowledge of safe practices.
Comment  by Ralph : Anybody building a boiler should read K.N.Harris or consult the current ISO or DIN regs pertaining to pressure usage BS is not longer applicable. I am very practiced in the design and usage of pressure systems. Most of the computers that I designed used pressurised Sulphur Hexaflouride at 6 BAR using 400 series stainless steels. If you read the comments further down the thread you will see that I specifically mention CE marked boilers and Pressure testing.
hornbeam
Really appreciate the photos and details.
Given me food for thought, what is the distance between frames?
Thanks.
Matthew (11) has just pointed out that it would be possible to use a brand new boiler for a Mamod with the associated gas heating and pressure regulation available from PSS Steam to power your tram with USE motors. How much you gear them down is up to you -but given the "top speed"(?) of one of them I would suggest somewhere in the region of 10:1 to 20:1. The easiest way to do this is to use a worm and spur setup. Ideally you would need TWO "starts" on your worm and the worm will need to be supported at both ends -to stop high revs wobbling! I normally use Muffet gears -the Hostaform gears are superb and are not to be despised. But the nylon gears from Technobots are also suitable. One word about using and cutting Hostaform -it generates vast amounts of static and seems to be impossible to get out of woolen jumpers! Stick to MOD1 gears as this makes the maths easy (i.e. a 20 tooth spur is 20mm diameter...)
As to your platform a sheet of ply with a some Aluminium or Brass laminated to it with epoxy will provide all the support you need -as well as being light and strong.
Have fun and remember we are always here to help you.
Hi Hornbeam,
Just a few thoughts - both for your project and for anyone else looking to build a tram-type engine.
First, it seems to me that quite a few modellers have a bit of a barrier when it comes to the engineering side of life. A few very simple skills and tools are all that would be required to make your own frames. An engineers square (for making 90 degree 'scribes') a small hacksaw and a medium file would produce the four 'sides' from 2mm x (say) 30mm wide mild steel strip. As the frames are esentially four rectangles - it could be done in an evening. You already have a drill - all you need to make these simple frames. The LBSC way was to use angle in the corners and screw them together. Still works just fine.
Making wheels, axles, bushes is more of a problem without a lathe - but not insurmountable. For instance - Brandbright sell very nice steel (3 hole) wagon wheels (with axles) which could be used either with outside frames and very simple axles boxes or inside frames with oilite bushes. I would not worry about coupling rods - you cannot see them on this engine - as its all hidden behind the skirts. As Cabbage suggests - a chain drive between axles is much simpler to arrange and the wheel you have removed can be simply Loctited back in place once you have your sprocket (and bushes if inside frames are used) on the axle.
With regards steam motors and boilers - well there are quite a few choices - although I have to say live steam within an enclosed resin body would not be my ideal choise (great for battery electric though).
Cannot tell you about GRS dimensions - but the G3 standard for the wheel back to back measurement is 58mm - so deduct 2mm (for clearance) and 2 x frame thickness (e.g. if 2mm thick = 4mm) and that will be the inside frame dimension required.
This probably all sounds a bit daunting - but having done it once, I think you will see how much better it is to be able to make these things yourself. It is not only a lot cheaper but also much easier when you want to do something that little bit different and there is no good way to do it with modified parts.
Not that I have any problem with modifying commercial bits - it's just that it's also very useful to have the choice - and the confidence to do so. The tram engine is an ideal type of engine to learn some very useful skills in my view.
Whichever way you go though - enjoy it and have fun!
Ian T
hornbeam
Many thanks guys. Have no idea why I didnt think of making the frames/ chassis myself. This is the route i'll take and will keep you updated. In needs to be done as and when I can afford the parts. I think ive now got my hand on a boiler.
hornbeam
Another silly question. Any ideas on a good supplier of material for the frames? Looked on E-bay but postage puts me off. Guessing I could try sheet metal places for off cuts.
Excellent - that's the hard part over (deciding to try!)
I tend to have quite a bit of MS scrap available for most small jobs - but it sometimes saves quite a lot of time & effort to buy material that is at least the right thickness and width. Ideally I try to have a list ready for any shows I'm going to (Guildford is my favorite) - but it doesn't always work out like that.
I've used CES (College Engineering Supplies) for these 'special' bits in the past - and I've just had a quick look at their website here:
http://www.collegeengineering.co.uk/Materials/steelflatblock.htm
As you will see - they supply mild steel 'flat' in 12" lengths and it isn't that expensive - 1/16th (1.6mm) will probably be good enough for this job - although 3/32nd (2.4mm) will make a real 'heavy duty' frame. You'll need to work out the frame depth required though. I'd give CES a call and ask how much to post three lengths in the width you require. They are pretty helpful.
Nearly forgot - you will also need some MS 'angle' - 12" of the 16x16x3mm should do for the whole engine.
As Cabbage says - let us know if you need any advice - it's one of the reasons the Forum exists.
Ian T
Try "Rob" at Mallard Metal Packs. www.mallardmetals.co.uk He supplies me with all the bits cut to roughly the size I need. You need to clean all the metal beforehand though. I do not know what "Rob" using for cutting coolant but it leaves a layer that I would only describe as "chinese chicken dripping". Any de-greaser will work -even a bottle of "Fairy Liquid"...
To add to IanT's point about wheels and axles, if asked Brandbright will supply the wheels and axles as individual parts. The Brandbright axle is 1/4 inch or 6.3mm most gears are either this or 6mm bore -check you have the correct size drill for the job!!!
Steel is cheap -but Brass is easier to work (and it solders well). Small scale silver soldering can be done with a cooks blow torch -failing that stick to epoxy and use M5 or M4 threaded bar as your frame spacers and then epoxy the nuts to the side frames. I have made frames from Brass, Steel, and Paxolin sheet using this technique. As to having "just a pillar drill" -relax!!! I started making locos in 2001 with a black and decker in a press fitting. I bought a Mill and Lathe in 2008 when I had to -to make a specific wheel that everyone model engineering company said was impossible to make. Unlike other members of this forum I am a confirmed cheapskate and my "trains" budget is £10 per week.
The mark of a true scratch builder is not "how much does it cost to build?" but rather "where can I scrounge the bits to build it?"
Good luck with your boiler -remember it will need to be tested before you even contemplate raising steam or buy one from a certified Source CE marked(!). Boring though it may be to have it done, better this than digging out pieces of boiler from your flesh...
Keep us posted and good hunting!!!
Hornbeam - just thinking about the mutitudinous ways you could aproach something as (apparently) simple as the basic frame - and I think we would very much appreciate the odd update as to what you decide to do - and why...
For instance  - to spring or not to spring?
'Unsprung' enables very simple axle 'holes' to be used - maybe with some thicknessing plates added to make a better bearing surface - or for oilite bushes to be pushed into.
'Sprung' could be simply elongating one set of holes (as above) and allowing one axle to move vertically by a little bit - or something more 'technical' such as brass axle boxes set in angle-iron guides with coil springs above...
All of these methods work by the way - but part of the fun is deciding how you are going to do it.
Enjoy!
Ian T
hornbeam
ive started sketching things out and hopefully have a Accucraft boiler sorted and have a burner and gas tank in stock. Will order material in the new year. Any good supliers of the gears and chain? Im currently looking at seeing if I can use ossy cylinders from PPS steam models along with their reversing block but need to work out how to fit it and connect the cylindrs up to the wheels. Reason for thinking this is that the GRS motor is so expensive, but at least its geared, either way it may need to go below the boiler between the frames. Progress will be slow no doubt.  ;D
Just seen Cabbages latest post - and agree generally with what he says but do want to make one comment.
The use of brass and nickel silver is generally preferred in the smaller scales - as the use of "fasteners" to hold things together is far less common in these scales (size is an issue) and the use of solder or adhesives more the norm.
However - in G3 it is much easier to use a "nut & bolt" approach to most things - and this does have some advantages. You can disassemble things (for maintenance & painting for instance) and it also makes it easy to use cheaper materials such as mild steel. Mild steel is stronger (weight for weight) and takes a paint finish better than brass - so has its advantages too.
I make this point because I think we tend to use those things we are most familiar with and sometimes modellers who are 'upscaling' to G3 can forget that other methods and materials are available to them in the larger scale.
Ian T
